Volvo Volvo XC90 ODB адаптер и конфиг
Volvo
Denis040280
1 Май 2025
Костанай, Казахстан
Заказал Noname OBD адаптер с сетевым кабелем и считал конфиг машины Vtool. Пока нет возможности его поменять, а пару параметров я уже присмотрел… Изучаю дальше.
1 < | | > VEHICLE TYPE < | | > V526 < | | > 04
2 < | | > DOORS < | | > 5 doors < | | > 01
3 < | | > TRANSMISSION — DRIVELINE < | | > All wheel drive < | | > 02
4 < | | > ELECTRIC DRIVELINE < | | > Without power flow < | | > 01
5 < | | > ENGINE < | | > VED4 HP 2.0L 235/480 < | | > 16
6 < | | > FUEL < | | > Diesel < | | > 02
7 < | | > ENGINE GENERATION < | | > VEA2 VEA generation 1 < | | > 01
8 < | | > STEERING WHEEL POSITION < | | > Left hand drive < | | > 01
9 < | | > GEARBOX < | | > AWF22AWD, Automatic 8-speed AWD < | | > 04
10 < | | > GEARBOX, TYPE < | | > Automatic gearbox < | | > 02
11 < | | > FUEL TANK, VOLUME < | | > 71 L < | | > 01
12 < | | > FUEL TANK SENSOR < | | > 2 sensors < | | > 02
13 < | | > PROPULSION TYPE < | | > Combustion engine < | | > 01
14 < | | > REMOTE MONITORING SYSTEM < | | > Remote monitoring system deactivated < | | > 01
15 < | | > TURBO CONFIGURATION < | | > High performance < | | > 02
16 < | | > POWER STEERING PERSONALISATION < | | > Electro Power Steering, Personalization < | | > 02
17 < | | > TYRE DIMENSION < | | > 275/45R20 < | | > 08
18 < | | > TYRE ROLLING CIRCUMFERENCE < | | > Rolling circumference 2305 mm < | | > 79
19 < | | > TYRE PRESSURE MONITORING SYSTEM < | | > Without TPMS < | | > 01
20 < | | > TPMS MENU FUNCTIONS < | | > With TPMS menu, reset < | | > 02
22 < | | > START DEVICE < | | > Start knob, two rotation directions < | | > 01
23 < | | > CRUISE CONTROL < | | > Adaptive cruise control stop & go, level 1 < | | > 04
24 < | | > SEATS < | | > 5 seats < | | > 02
25 < | | > SEAT HEAT CALIBRATION < | | > Heat calibration 4 < | | > 04
26 < | | > HUMIDITY SENSOR CALIBRATION < | | > Calibration #1 < | | > 01
28 < | | > RADIO, AMP AND SPEAKER SYSTEM < | | > High performance audio < | | > 02
29 < | | > ELECTRIC VEHICLE INLET < | | > Without electric vehicle inlet < | | > 01
30 < | | > BATTERY < | | > H7 80Ah 800 Cold Cranking Ampere, AGM < | | > 03
31 < | | > ALTERNATOR < | | > Alternator 210 A < | | > 01
32 < | | > LOW VOLTAGE ELECTRICAL CONFIGURATION Conventional Vehicle < | | > Without Start Stop, One Battery < | | > 01
33 < | | > STRAW IN FUEL RESERVOIR < | | > Without Straw < | | > 01
34 < | | > ENGINE THERMOSTAT HEATING < | | > With heater element < | | > 02
35 < | | > OIL SUMP TYPE Oil sump ( < | | > With bulge) < | | > 02
36 < | | > ADJUSTABLE SPEED LIMITER < | | > Adjustable speed limiter (ASL) and adjustable variable speed limiter (AVSL) < | | > 03
37 < | | > GEARSHIFT INDICATOR < | | > With < | | > 02
38 < | | > ENGINE COOLING FAN PERFORMANCE < | | > High < | | > 03
39 < | | > SHIFT BY WIRE < | | > Without shift by wire < | | > 01
40 < | | > ACTIVE GRILLE AND SPOILER SHUTTERS < | | > With active grille and spoiler shutters < | | > 04
41 < | | > GEAR SHIFT PADDLES < | | > Without < | | > 01
42 < | | > PART NUMBER FORMAT < | | > KDP format < | | > 01
43 < | | > MAX VEHICLE SPEED LIMITATION < | | > Speed limit 230 km/h < | | > 1C
44 < | | > STOP IN SPEED VELOCITY < | | > Stop in speed 7 km/h < | | > 09
45 < | | > ENGINE REMOTE START PRECOND < | | > Engine remote start (preconditioning) from smartphone app < | | > 02
46 < | | > DIAGNOSIS SYSTEM < | | > EOBD < | | > 02
47 < | | > SELECTIVE CATALYTIC REDUCTION < | | > Without UREA < | | > 01
48 < | | > OIL LEVEL SENSOR < | | > Oil level sensor < | | > 02
49 < | | > PERFORMANCE MODE < | | > Without performance mode < | | > 01
50 < | | > CHASSIE TYPE < | | > Center Console Display (CCD) < | | > 04
51 < | | > TRAILER STABILITY ASSIST < | | > With < | | > 02
52 < | | > POST-IMPACT BRAKING < | | > With post-impact braking < | | > 02
53 < | | > HILL DESCENT CONTROL < | | > Hill descent control < | | > 02
54 < | | > WHEEL BRAKES TYPE REAR < | | > Brake discs 17" 320x20 GG < | | > 02
55 < | | > WHEEL BRAKES TYPE FRONT < | | > Brake discs 18" FN < | | > 03
56 < | | > BRAKE PADS < | | > Standard pad < | | > 01
57 < | | > DRIVE MODE < | | > With drive mode switch < | | > 02
58 < | | > AIR SUSPENSION < | | > Air suspension, four corners < | | > 03
59 < | | > ACTIVE SUSPENSION < | | > With continously controlled chassis < | | > 02
60 < | | > LEVELLING SENSOR CONFIGURATION < | | > SUM, front left, front right, rear left, rear right < | | > 09
61 < | | > HILL START ASSIST < | | > With hill start assist < | | > 02
62 < | | > FRONT AXLE WEIGHT < | | > Unknown value < | | > 6F
63 < | | > REAR AXLE WEIGHT < | | > Unknown value < | | > 61
64 < | | > ALARM < | | > Without alarm < | | > 01
65 < | | > INTERIOR MOTION SENSOR < | | > Without < | | > 01
66 < | | > INCLINATION SENSOR < | | > Without inclination sensor < | | > 01
67 < | | > STEERING COLUMN LOCK < | | > With Steering Column Lock variant 1 < | | > 02
68 < | | > PANIC FUNCTION Panic function < | | > With light and sound < | | > 03
69 < | | > RETRIGG ENABLING, IF ALARM < | | > 1 cycle < | | > 01
70 < | | > PASSIVE ARMING < | | > Without passive arming < | | > 01
71 < | | > FOREIGN COMPONENT DETECTION < | | > Without foreign component detection < | | > 01
72 < | | > IMMOBILISER < | | > Immobilizer for 1 target < | | > 01
73 < | | > KEY WARNING < | | > Without key warning < | | > 01
74 < | | > ATTENUATION UPHOLSTERY < | | > Low attenuation upholstery < | | > 03
75 < | | > THEFT NOTIFICATION < | | > With theft notification < | | > 02
76 < | | > STOLEN VEHICLE TRACKING < | | > With stolen vehicle tracking < | | > 02
77 < | | > ASSISTANCE SERVICES < | | > With assistance service < | | > 02
78 < | | > HOMELINK FREQUENCY SETTING < | | > Without Homelink < | | > 01
79 < | | > CAR SHARING FUNCTION < | | > Without < | | > 01
80 < | | > KEYLESS ANTENNAS < | | > With four keyless antennas < | | > 03
81 < | | > DOOR HANDLE TYPE < | | > Capacitive door handle < | | > 02
82 < | | > CHARGE LID LOCK < | | > Without electric charge lid < | | > 01
83 < | | > FUEL LID LOCK < | | > With electric fuel lid opening < | | > 02
84 < | | > CAR LOCK TYPE < | | > Volvo key algorithm < | | > 02
85 < | | > CENTRAL LOCK, TYPE < | | > Without blocked lock mode < | | > 01
86 < | | > CENTRAL LOCK SWITCHES < | | > Central lock switches in both front doors < | | > 02
87 < | | > CHILD LOCK < | | > Electrical child lock, rear doors < | | > 02
88 < | | > PRIVATE LOCKING, TRUNK < | | > Disabled < | | > 01
89 < | | > SLAM LOCKING < | | > Disabled < | | > 01
90 < | | > AUTOMATIC LOCKING BY SPEED < | | > Automatic locking by speed enabled, on by default < | | > 02
91 < | | > TWO STEP UNLOCKING < | | > Two step unlocking off by default < | | > 01
92 < | | > FREQUENCY, REMOTE CONTROLS < | | > 434 MHz < | | > 02
93 < | | > AUTHENTIC COMMUNICATION OF LOCKING COMMANDS < | | > Locking commands not encrypted < | | > 01
94 < | | > KEYLESS ENTRY < | | > With keyless entry via Personal Car Communicator, including remote tag < | | > 02
95 < | | > VISIBLE LOCKING/UNLOCKING < | | > With visual feedback on locking and unlocking, on by default < | | > 02
96 < | | > AUDIBLE LOCKING FEEDBACK < | | > Disabled < | | > 01
97 < | | > TRUNK RELEASE, POP-UP < | | > Without power-operated tailgate or trunk lid < | | > 01
98 < | | > SELF OPENING BOOTLID/TAILGATE < | | > With power operated tailgate or trunk lid < | | > 02
99 < | | > HANDSFREE OPENER, BOOTLID/TAILGATE < | | > Foot movement detection module < | | > 02
100 < | | > AUTONOMOUS DRIVE < | | > No Autonomous Vehicle < | | > 01
101 < | | > FMDM GENERATION < | | > Undefined < | | > 00
102 < | | > DESIGNED POSITION LIGHT < | | > Undefined < | | > 00
103 < | | > EXTERIOR LIGHTS SIGNATURE < | | > Undefined < | | > 00
104 < | | > TURN SIGNAL TYPE < | | > Standard < | | > 01
105 < | | > WELCOME & GOODBYE LIGHTS TYPE < | | > Without < | | > 01
106 < | | > HEADLIGHTS, TYPE LED < | | > With bending light, type B, high range < | | > 06
107 < | | > EXTERIOR LIGHT LOGIC Dedicated daytime running lights not together < | | > With position lights < | | > 01
108 < | | > DRL TYPE < | | > Dedicated daytime running light (DDRL) and Position light Off During DI < | | > 04
109 < | | > ACTIVE HIGH BEAM < | | > With active high beam 2 (adaptive), low beam in village < | | > 04
110 < | | > REAR FOGLIGHT TOW FUNCTION < | | > Rear fog lights disabled during towing < | | > 02
111 < | | > TOURIST LIGHT Right asymmetry < | | > With configurable tourist light < | | > 03
112 < | | > CORNERING LIGHT < | | > Cornering light < | | > 02
113 < | | > FOGLIGHT/FUNCTION IN SPOILER < | | > Without front fog light restrictions < | | > 01
114 < | | > EMERGENCY BRAKE LIGHT < | | > With emergency brake light — flashing brake lights and hazard warning lights < | | > 02
115 < | | > FRONT FOGLIGHT, FUNCTION IN SPOILER < | | > With fog lights, LED < | | > 02
116 < | | > DRL TECHNOLOGY < | | > With daytime running lights, LED, combined With position lights < | | > 03
117 < | | > DOOR HANDLE LIGHT < | | > With door handle light on all door handles < | | > 02
118 < | | > AUTOLIGHT FUNCTION < | | > Without configurable light sensitivity thresholds < | | > 03
119 < | | > AUXILIARY LIGHTS < | | > Without < | | > 01
120 < | | > WINDSCREEN WIPERS < | | > Wet arms, heated < | | > 03
121 < | | > HEADLIGHT CLEANING OPTION < | | > With headlight cleaning < | | > 02
122 < | | > HEATED WINDSCREEN < | | > Without < | | > 01
123 < | | > IR REFLECTIVE GLASS WINDSCREEN < | | > Standard windshield glass < | | > 01
124 < | | > REAR WINDOW WIPER < | | > With rear window wiper and washer < | | > 02
125 < | | > AUTOMATIC LUGGAGE CONCEALING < | | > With automatic luggage concealing < | | > 02
126 < | | > PASSENGER AIRBAG TYPE Passenger airbag < | | > With 1-stage inflator < | | > 04
127 < | | > SEAT TRACK SENSORS < | | > Without seat track sensors < | | > 01
128 < | | > LAP BELT PRETENSIONER < | | > Without < | | > 01
129 < | | > PYRO-TECHNICAL STEERING COLUMN < | | > Without pyrotechnical steering column < | | > 01
130 < | | > ADAPTIVE LOAD LIMITER FRONT < | | > Without < | | > 01
131 < | | > OCCUPANT WEIGHT SENSOR < | | > Without occupant weight sensor < | | > 01
132 < | | > CUTOFF SWITCH PASSENGER AIRBAG < | | > With < | | > 02
133 < | | > KNEE AIRBAG < | | > With knee airbag, driver side < | | > 02
134 < | | > AIRBAG, PASSENGER SIDE < | | > Passenger airbag not disabled < | | > 02
135 < | | > ELECTRICAL REVERSIBLE RETRACTORS < | | > With reversible electrical seat belt pretensioners < | | > 02
136 < | | > PEDESTRIAN PROTECTION < | | > Without pedestrian protection < | | > 01
137 < | | > THIRD ROW BELT BUCKLE DETECTION < | | > Without third row belt buckle detection < | | > 01
138 < | | > SECOND ROW BELT BUCKLE DETECTION < | | > With second row belt buckle detection, left, right, and center seats < | | > 03
139 < | | > BUMPER TYPES < | | > Standard front bumper < | | > 01
140 < | | > SKIDPLATE REAR < | | > Without rear skid plate (accessory) < | | > 01
141 < | | > NIGHT VISION < | | > Without < | | > 01
142 < | | > PARKING ASSISTANCE < | | > Parking assistance, semi-automatic parking (SAP) < | | > 04
143 < | | > DRIVER IMPAIRMENT MONITOR < | | > With < | | > 02
144 < | | > DISTANCE ALERT < | | > With distance alert < | | > 02
145 < | | > TRAFFIC JAM ASSIST < | | > With Traffic Jam Assist, Level 2 < | | > 03
146 < | | > COLLISION MITIGATION SUPPORT FRONT < | | > With Collision Mitigation Support Front, ver.1 < | | > 02
147 < | | > ROAD FRICTION INFORMATION < | | > With Connected Safety level 1 < | | > 02
148 < | | > CURVE SPEED SUPPORT < | | > Without curve speed warning or curve speed assistance < | | > 01
149 < | | > ROAD SIGN INFORMATION Mid-EU: Road sign information < | | > Without speed limit adaptation < | | > 08
150 < | | > LANE KEEPING AID < | | > With lane keeping aid < | | > 02
151 < | | > ELECTRONIC HORIZON < | | > With electronic horizon < | | > 02
152 < | | > BLIND SPOT INFORMATION SYSTEM < | | > With blind spot information system and cross traffic alert < | | > 02
153 < | | > COLLISION MITIG < | | > With rear collision warning and mitigation < | | > 02
154 < | | > PARKING CAMERA < | | > Parking camera 360 < | | > 03
155 < | | > SPEED WARNING < | | > Without speed warning < | | > 01
156 < | | > REAR WIEW MIRRORS, OUTER < | | > With retractable mirrors < | | > 02
157 < | | > COMBINED INSTRUMENT Driver Information Module (DIM) < | | > With 12.3" screen < | | > 02
158 < | | > HEAD UP DISPLAY < | | > Graphical Head-up Display (GHUD) < | | > 02
159 < | | > SAFETY BELT REMINDER < | | > Seat belt reminder, all seats, EU logic < | | > 03
160 < | | > INSTRUMENT CLUSTER CALIBR < | | > Parameter file for Europe < | | > 04
161 < | | > UNIT SETTINGS < | | > Temperature: C. Clock: 24 h. Distance: km. Fuel: liter/km < | | > 01
162 < | | > SERVICE DISTANCE < | | > Service interval 30 000 km / 18 640 miles < | | > 3C
163 < | | > SERVICE TIME < | | > 12 months < | | > 03
164 < | | > SERVICE ENGINE TIME < | | > 650 hours < | | > 0D
165 < | | > AMBIENT TEMP TABLES < | | > 1 < | | > 01
166 < | | > EXTENDED SPEED INDICATION < | | > Without extended speed indication < | | > 01
167 < | | > TRIP COMPUTER AND STATISTICS < | | > With trip computer and With trip stattistics < | | > 04
168 < | | > SCREEN THEMES/SKINS < | | > Screen Skins 'Inscription' < | | > 03
169 < | | > CLEAN COMPARTMENT < | | > With clean compartment < | | > 02
170 < | | > HVAC, REAR < | | > Without rear ventilation and air conditioning < | | > 01
171 < | | > FUEL OPERATED ADDITIONAL HEATER < | | > Without additional heater < | | > 01
172 < | | > REFRIGERANT < | | > 1234YF < | | > 01
173 < | | > AC COMPRESSORS < | | > Mechanical A/C, 160 cc < | | > 02
174 < | | > AIR QUALITY SYSTEM < | | > With air quality system, With multifilter < | | > 02
175 < | | > HVAC VARIANTS < | | > HVAC Large, 2 zone ECC < | | > 01
176 < | | > REAR VIEW MIRROR TYPE < | | > Automatic dimming of inner and outer rear view mirror < | | > 03
177 < | | > ROOF HATCH < | | > Without roof hatch or panorama roof < | | > 01
178 < | | > PINCH PROTECTION LEVEL < | | > Standard pinch protection < | | > 01
179 < | | > FRONT SEAT VENTILATION < | | > With front seat ventilation < | | > 02
180 < | | > HEATED FRONT SEATS < | | > With < | | > 02
181 < | | > HEATED REAR SEAT < | | > Without < | | > 01
182 < | | > PARKING CLIMATE LEVEL < | | > Afterrun parking climate < | | > 02
183 < | | > INTERIOR ILLUMINATION < | | > Interior lighting, high version < | | > 02
184 < | | > POWER SEATS < | | > Driver and passenger memory seats < | | > 04
185 < | | > POWER FOLD & RISE 3:d ROW < | | > No fold and rise, 3rd row rear seat < | | > 01
186 < | | > HEATED STEERING WHEEL < | | > Without heated steering wheel < | | > 01
187 < | | > HEADRESTS 2:nd ROW, FOLDING < | | > Folded manually < | | > 01
188 < | | > TINTED TAILGATE WINDOW < | | > With tinted tailgate window < | | > 02
189 < | | > REAR SEAT VENTILATION < | | > Without rear seat ventilation < | | > 01
190 < | | > GLOBAL NAVIGATION SAT SYSTEM < | | > With Global Navigation Satellite System < | | > 02
191 < | | > TELEMATIC MODULE < | | > With Telematic module, ROW LTE < | | > 06
192 < | | > IHU LEVEL < | | > High < | | > 02
193 < | | > DIGITAL RADIO RECEIVER < | | > DAB radio system < | | > 02
194 < | | > REAR SEAT ENTERTAINMENT < | | > Without < | | > 01
195 < | | > REGION IF DVD < | | > Region 2 < | | > 03
196 < | | > Wi-Fi FREQUENCY BAND < | | > 2.4 GHz < | | > 01
197 < | | > SYSTEM LANGUAGE < | | > German < | | > 0F
198 < | | > SPEECH < | | > With speech < | | > 02
199 < | | > SPEECH LANGUAGE < | | > English (UK) < | | > 07
200 < | | > Wi-Fi FUNCTIONALITY CONTROL < | | > With Wi-Fi station mode and Wi-Fi access point < | | > 04
201 < | | > CONNECTIVITY < | | > Connectivity < | | > 02
202 < | | > OWNERS MANUAL < | | > Digital owner's manual < | | > 02
203 < | | > MESSAGING < | | > Enabled < | | > 02
204 < | | > TV TUNER < | | > Without TV tuner < | | > 01
205 < | | > DSRC UNIT < | | > Without < | | > 01
206 < | | > DUAL MEDIA VICS ANTENNA < | | > Without < | | > 01
207 < | | > VIDEO ALLOWED < | | > Speed dependent < | | > 03
208 < | | > DRIVER DISTRACTION PROTECTION < | | > Driver Distraction protection B < | | > 03
209 < | | > ROAD AND TRAFFIC INFO, RTI < | | > RTI map Europe < | | > 02
210 < | | > SUBWOOFER < | | > Subwoofer < | | > 02
211 < | | > TRAILER MODULE, AFTERMARKET Trailer Module < | | > With 13-pos socket, electric semi-retractable towbar < | | > 04
212 < | | > ALCOLOCK < | | > Without alcolock < | | > 01
213 < | | > RUNNINGBOARD, ACCESSORIES < | | > Without running board < | | > 01
214 < | | > RESTRICTED KEY FUNCTION < | | > Without restricted key function < | | > 01
215 < | | > DECO TRIM ILLUMINATION < | | > Without deco trim illumination < | | > 01
216 < | | > ACCESSORY GATEWAY UNIT < | | > Without accessory gateway unit < | | > 01
218 < | | > MARKET TELEPHONE NETWORK < | | > Telephone system GSM < | | > 01
219 < | | > MICROPHONE SETUP < | | > With three digital handsfree microphones < | | > 04
220 < | | > LANGUAGE REGION < | | > Language region: Europe < | | > 02
221 < | | > CONNECTED SERVICE BOOKING < | | > With connected service booking < | | > 02
222 < | | > MEDIAPLAYER < | | > Without media player < | | > 01
223 < | | > NAVIGATION SYSTEM AND INTERNET MAP < | | > With connected navigation, With internet map < | | > 04
224 < | | > DEVICE MIRRORING < | | > With device mirroring, CarPlay & AndroidAuto < | | > 04
225 < | | > TYRE PRESSURE LLF < | | > 0 — 160 km/h, light load, front, 240 kPa < | | > 05
226 < | | > TYRE PRESSURE LLR < | | > 0 — 160 km/h, light load, rear, 220 kPa < | | > 03
227 < | | > TYRE PRESSURE LHF < | | > 0 — 160 km/h, heavy load, front, 270 kPa < | | > 08
228 < | | > TYRE PRESSURE LHR < | | > 0 — 160 km/h, heavy load, rear, 270 kPa < | | > 08
229 < | | > TYRE PRESSURE HLF < | | > >160 km/h, light load, front, 240 kPa < | | > 05
230 < | | > TYRE PRESSURE HLR < | | > >160 km/h, light load, rear, 240 kPa < | | > 05
231 < | | > TYRE PRESSURE HHF < | | > >160 km/h, heavy load, front, 270 kPa < | | > 08
232 < | | > TYRE PRESSURE HHR < | | > >160 km/h, heavy load, rear, 270 kPa < | | > 08
235 < | | > PHONE AS KEY < | | > No Phone as Key < | | > 01
237 < | | > DEFAULT RIDE HEIGHT Default ride height < | | > With air suspension < | | > 02
238 < | | > TOP DAMPING, BRAKES Friction brake actuator < | | > With top damping < | | > 02
239 < | | > MASSAGE FRONT SEAT < | | > Without Massage, front seat < | | > 01
240 < | | > LUMBAR SUPPORT < | | > 4 way lumbar support < | | > 02
241 < | | > CUSHION EXTENSION < | | > With seat cushion extension, driver and passenger sides < | | > 03
242 < | | > HEADRESTS FRONT < | | > 2-way manual front headrests < | | > 01
243 < | | > POWER ADJUSTABLE SIDE SUPPORT < | | > With power adjustable side support < | | > 02
244 < | | > REMOTE CONTROL OF PASSENGER SEAT FUNCTIONS < | | > With remote control of passenger seat < | | > 02
245 < | | > EASY INGRESS EGRESS < | | > Without easy ingress and egress < | | > 01
246 < | | > POWER RELEASE 2:nd ROW < | | > Mechanical release fold 2:d row rear seat < | | > 03
247 < | | > HVAC FILTER TYPE < | | > With multifilter < | | > 02
248 < | | > IAQS SMOKE SENSOR < | | > Without smoke sensor < | | > 01
249 < | | > OVERHEAD CONSOLE TYPE < | | > OHC Original < | | > 02
250 < | | > ELECTRIC DISTANCE TO EMPTY < | | > Non BEV vehicles < | | > 01
253 < | | > FRONT DIRECTION INDICATOR LAMP TYPE LED < | | > With "Bulb" diagnostic mode < | | > 03
254 < | | > REAR DIRECTION INDICATOR LAMP TYPE < | | > LED < | | > 02
255 < | | > REAR FOGLIGHT LAMP TYPE Single-sided < | | > LED < | | > 04
256 < | | > BENDING LIGHT < | | > With bending light < | | > 02
257 < | | > REAR POSITION LAMP TYPE < | | > LED < | | > 02
258 < | | > REAR STOP LEFT/RIGHT LAMP TYPE < | | > LED < | | > 02
259 < | | > REVERSING LAMP TYPE < | | > Bulb, double-sided < | | > 01
260 < | | > CARE KEY RESTRICTION LEVEL < | | > Without restrictions < | | > 01
262 < | | > THERMAL MANAGEMENT < | | > Thermal Management, gen 1 < | | > 01
263 < | | > HEAT PUMP < | | > Without Heat Pump < | | > 01
267 < | | > INDIRECT TPMS SYSTEM < | | > Indirect TPMS, EU algorithm < | | > 04
268 < | | > NUMBER OF CYLINDERS < | | > 4 cylinders < | | > 01
270 < | | > VEM INFOTAINMENT SETTINGS < | | > No High Voltage Battery Optimization, no HMI Button, no Cloud Access < | | > 01
271 < | | > STOP START FUNCTION MEMORY Button < | | > Without memory, Standard symbol < | | > 01
273 < | | > ADAPTIVE REAR LIGHT (ARL) AVAILABILITY < | | > Undefined < | | > 00
274 < | | > HEADLAMP PROJECT, FOR HCM < | | > Undefined < | | > 00
275 < | | > REAR SEAT REMOTE FUNCTIONALITY < | | > Without Rear Seat Remote Functionality < | | > 01
289 < | | > ESCALATED EMERGENCY STOP < | | > Without EES < | | > 01
290 < | | > OCCUPANT SAFE POSITIONING < | | > OSP Gen1 < | | > 01
291 < | | > BRAKING LIGHT TYPE SPECIFICATION < | | > Undefined < | | > 00
301 < | | > DRIVER AIRBAG TYPE < | | > Driver airbag, stage 1 < | | > 01
302 < | | > RSDS VERSION < | | > RSDS2 < | | > 01
303 < | | > REAR SUBFRAME FASTENING < | | > Without pyrotechnical nuts for rear subframe fastening < | | > 01
304 < | | > KNEE AIRBAG, 2-STAGES < | | > Without < | | > 01
305 < | | > PARKING ASSISTANCE SENSOR GENERATION < | | > GEN5 < | | > 01
307 < | | > C-PILLAR SENSOR < | | > Without C-pillar sensors < | | > 01
308 < | | > SRS MARKET VARIANT < | | > SRS Calibration 01 < | | > 01
309 < | | > FORWARD LOOKING RADAR < | | > Undefined < | | > 00
310 < | | > FRONT SIDE RADARS < | | > Without front side radars < | | > 01
311 < | | > FLC VARIANT < | | > Without FLC < | | > 01
312 < | | > LANE CHANGE ASSIST < | | > Without Lane Change Assist < | | > 01
313 < | | > SAFETY COACH < | | > Without Safety Coach < | | > 01
314 < | | > ADAPTIVE CRUISE CONTROL VERSION < | | > ACC version 1 < | | > 01
315 < | | > DRIVE AWAY INFORMATION < | | > Without Drive Away Information < | | > 01
316 < | | > EMERGENCY LANE KEEPING AID < | | > With ELKA level 1 < | | > 02
317 < | | > EVASIVE MANOUEVRE ASSIST < | | > Without evasive maneuver assistance < | | > 01
318 < | | > AUTO PILOT FUNCTION (HAD ) < | | > Without autopilot < | | > 01
319 < | | > SAFETY BELT REMINDER 2ND ROW < | | > No rear seat occupant detection switches < | | > 01
321 < | | > BRAKE PULSE INTERFACE < | | > Brake request < | | > 01
322 < | | > CMS ONCOMING < | | > Without collision mitigation system With oncoming traffic scenario < | | > 01
323 < | | > REAR AUTOMATIC EMERGENCY BRAKING < | | > Without braking < | | > 01
324 < | | > VACUUM LESS BRAKE SYSTEM < | | > No Vacuum less brake system < | | > 01
325 < | | > PEDESTRIAN PROTECTION SYSTEM SENSOR CONFIGURATION < | | > Undefined < | | > 00
327 < | | > WHEEL ARCH EXTENSION < | | > Undefined < | | > 00
328 < | | > STARTER MOTOR < | | > With starter motor and cutoff pyro < | | > 02
335 < | | > HVAC FLOOR SENSORS < | | > With Floor sensors in HVAC < | | > 02
336 < | | > AIRBORNE PARTICULATE MATTER SENSOR < | | > Without Airborne Particulate Matter Sensor < | | > 01
337 < | | > CENTER CONSOLE SWITCH < | | > Without LIN communication < | | > 01
337 < | | > MODULE(CCSM) < | | > Without LIN communication < | | > 01
338 < | | > PRE_CLEAN < | | > Without Pre Clean < | | > 01
339 < | | > SECOND ROW CENTRE VENT < | | > Without second row center vent < | | > 01
340 < | | > ADVANCE AIR CLEANER IONIZER < | | > Without Advance Air Cleaner < | | > 01
341 < | | > CLIMATE SMALL COOLANT CIRCUIT < | | > Without Small Coolant Circuit < | | > 01
342 < | | > CLIMATE 2-WAY COOLANT VALVE < | | > Without 2-Way Coolant Valve < | | > 01
343 < | | > CLIMATE AUX WATER PUMP < | | > With Auxiliary water pump < | | > 02
344 < | | > LAMINATED WINDOWS < | | > Tempered glass, side and rear windows < | | > 01
345 < | | > BYPASS VALVE HVAC < | | > With bypass valve < | | > 02
346 < | | > SUN CURTAIN REAR WINDOW < | | > Without electric sun curtain, rear window < | | > 01
347 < | | > HEATER TYPE < | | > Without heater < | | > 01
348 < | | > HEX-TEMPERATURE SENSOR < | | > With hex temperature sensor < | | > 02
349 < | | > IONIC INTERNAL AIR CLEANER < | | > Without ionic internal air cleaner < | | > 01
350 < | | > MEMORY BUTTONS, IF POWER SEAT < | | > Three memory positions < | | > 01
351 < | | > SUN CURTAIN SIDEWINDOW REAR < | | > With sun curtain, rear side windows < | | > 02
352 < | | > SUN SENSOR < | | > With sun sensor, LIN (3D) < | | > 02
353 < | | > HUMIDITY SENSOR < | | > With humidity sensor < | | > 02
354 < | | > COMPARTMENT TEMPERATURE SENSOR < | | > In car TempSensor < | | > 03
355 < | | > PTC IN FRONT HVAC < | | > Without PTC < | | > 01
356 < | | > SECOND ROW SIDE VENT < | | > With second row side vent < | | > 02
357 < | | > REAR PASSENGER DOOR SWITCHPACK < | | > Without RPDS < | | > 01
358 < | | > ACTIVE NOISE CONTROL < | | > Without active noise control < | | > 01
359 < | | > EXTERIOR SOUND, HMI OPTION < | | > Without exterior sound HMI < | | > 01
360 < | | > FREQUENCY BAND & STEP, AM/FM HD RADIO < | | > Frequency band and step for Europe < | | > 01
361 < | | > SIM CARD FOR CONNECTIVITY < | | > Connectivity only through personal SIM card < | | > 02
362 < | | > USB CONNECTION < | | > With USB hub < | | > 03
363 < | | > AUDIO AUXILIARY INPUT < | | > With auxiliary audio input < | | > 02
364 < | | > Exterior Sound Module Calibration Types < | | > Without ESM calibration < | | > 01
365 < | | > Wi-Fi WORKSHOP MODE FUNCTIONAL CONTROL < | | > WLAN workshop mode enabled < | | > 02
366 < | | > WIRELESS PHONE CHARGER < | | > Without inductive charging for smartphone < | | > 01
367 < | | > REMOTE BATTERY MANAGEMENT < | | > Without remote battery management from smartphone app < | | > 01
368 < | | > ENGINE FAMILY TYPE < | | > VED HP < | | > 05
369 < | | > HV BATTERY SYMBOL < | | > Without < | | > 01
371 < | | > EXTERIOR SOUND SYSTEM < | | > Without < | | > 01
372 < | | > TELEMATICS NODE TYPE < | | > With vacuum sensor < | | > 02
373 < | | > PREMIUM TMC < | | > With < | | > 02
374 < | | > POLESTAR LEVEL < | | > Polestar < | | > 02
376 < | | > ISMOBILITY < | | > Without < | | > 01
377 < | | > INFOTAINMENT Param1 < | | > Without < | | > 01
379 < | | > INFOTAINMENT AUTOMOTIVE SERVICES < | | > Without Infotainment Automotive Services < | | > 01
401 < | | > RAIN SENSOR FUNCTION < | | > Rain sensor function operated by button < | | > 02
407 < | | > COOLANT LEVEL INDICATION < | | > With coolant level indication < | | > 02
408 < | | > REAR SUSPENSION TYPE < | | > Multi-link rear suspension < | | > 01
409 < | | > IMU SENSOR CONFIGURATION IMU < | | > With 2 degrees of freedom (lateral acceleration, yaw rate) < | | > 02
410 < | | > VACUUM SENSOR < | | > Without vacuum sensor < | | > 01
413 < | | > CONVENIENCE START < | | > Without < | | > 01
414 < | | > CONVENIENCE STOP < | | > Without < | | > 01
415 < | | > OCCUPANT DETECTION SENSOR DRIVER SEAT < | | > Without < | | > 01
441 < | | > VEHICLE PERSONA THEME < | | > Undefined < | | > 00
449 < | | > CDS VARIANTS < | | > Undefined < | | > 00
450 < | | > WIRELESS PHONE CHARGING (WPC) AND NEAR FIELD COMMUNICATION (NFC) < | | > Without wireless phone charging, Without near field communication < | | > 01
451 < | | > AUDIO & AMP LEVEL < | | > Undefined < | | > 00
452 < | | > DRIVE MODE SWITCH < | | > Undefined < | | > 00
453 < | | > GLOBAL NAVIGATION SATELLITE SYSTEM < | | > Undefined < | | > 00
454 < | | > AM RADIO FUNCTION < | | > With AM function < | | > 02
455 < | | > MIRACAST AND MIRRORLINK FUNCTION < | | > Undefined < | | > 00
456 < | | > BELT PRE-TENSIONER 2ND ROW < | | > Without seat belt pretensioner, shoulder, 2nd row < | | > 01
457 < | | > INFLATABLE CURTAINS < | | > Undefined < | | > 00
458 < | | > FRONT SIDE AIRBAGS < | | > With front side airbags (left and right) < | | > 02
459 < | | > STEERING WHEEL BUTTONS < | | > Undefined < | | > 00
460 < | | > AUDIO SPEAKERS < | | > Undefined < | | > 00
461 < | | > APPROVED CELLULAR STANDARDS < | | > No restrictions < | | > 01
462 < | | > HEATING MAT VARIANTS < | | > Both < | | > 02
463 < | | > MEMORY IN REAR VIEW MIRRORS < | | > Without < | | > 01
464 < | | > SUPERCAPACITOR < | | > Undefined < | | > 00
465 < | | > AIRBORNE PARTICULATE MATTER APMA < | | > Without < | | > 01
466 < | | > AMPLIFIER VARIANT < | | > Undefined < | | > 00
467 < | | > SHUTFACE BUTTONS ON TAILGATE/ BOOTLID < | | > Without < | | > 01
468 < | | > FIRST ROW TILT MOTORS < | | > Undefined < | | > 00
469 < | | > BOSS SWITCH < | | > Undefined < | | > 00
470 < | | > BELT PRE-TENSIONER 3RD ROW < | | > Undefined < | | > 00
471 < | | > BACKREST MOTORS 1ST ROW < | | > Undefined < | | > 00
472 < | | > FIRST ROW HEIGHT MOTORS < | | > Undefined < | | > 00
473 < | | > SECOND ROW MASSAGE < | | > Undefined < | | > 00
474 < | | > POWER SEAT 2ND ROW < | | > Undefined < | | > 00
475 < | | > FIRST ROW LEG REST < | | > Undefined < | | > 00
476 < | | > SECOND ROW LEG REST < | | > Undefined < | | > 00
477 < | | > EASY INGRESS EGRESS 2ND ROW < | | > Undefined < | | > 00
478 < | | > DOOR OPENING WARNING < | | > Undefined < | | > 00
479 < | | > FRONT CROSS TRAFFIC ALERT < | | > Undefined < | | > 00
480 < | | > NUMBER OF KEYLESS DOOR HANDLES < | | > Undefined < | | > 00
481 < | | > POWER DOOR TYPE < | | > Undefined < | | > 00
482 < | | > SEAT SPLIT SECOND ROW < | | > Undefined < | | > 00
483 < | | > DIGITAL VIDEO RECORDER < | | > Undefined < | | > 00
484 < | | > LOGO LIGHT < | | > Without < | | > 01
485 < | | > INTERIOR REAR VIEW MIRROR DISPLAY < | | > Undefined < | | > 00
486 < | | > SECOND ROW LUMBAR AND SIDE < | | > Undefined < | | > 00
486 < | | > SUPPORT < | | > Undefined < | | > 00
487 < | | > BRAKE PEDAL ACTIVE DECOUPLING PYR O < | | > Undefined < | | > 00
488 < | | > WIRELESS POWER TRANSFER MODULE < | | > Undefined < | | > 00
489 < | | > BLE/NFC KEYS < | | > Undefined < | | > 00
490 < | | > OUTER OPENING TRIGGER OF TAILGATE < | | > Soft < | | > 02
491 < | | > YEAR EDITION < | | > Undefined < | | > 00
492 < | | > REFRIGERANT EXPANSIVE VALVE TYPE < | | > Undefined < | | > 00
493 < | | > EMERGENCY LANE OCCUPIED WARNING < | | > Undefined < | | > 00
494 < | | > HIGHWAY ASSIST < | | > Undefined < | | > 00
495 < | | > PARKING ASSISTANCE SUPPORT PEB < | | > Undefined < | | > 00
496 < | | > BATTERY COOLANT LEVEL INDICATION < | | > Undefined < | | > 00
497 < | | > INTERIOR VIEW CAMERA < | | > Undefined < | | > 00
498 < | | > TEMPERATURE CONTROL CUP HOLDER < | | > Undefined < | | > 00
499 < | | > INFO TAINMENT HEAD UNIT TYPE < | | > Undefined < | | > 00
500 < | | > DRIVER ALERT CONTROL < | | > Undefined < | | > 00
501 < | | > WASHER FLUID LEVEL INDICATION FUNCTION < | | > Undefined < | | > 00
502 < | | > ELECTRICAL PARK BRAKE SWITCH < | | > Undefined < | | > 00
503 < | | > WIPER MOTOR MODULE < | | > Undefined < | | > 00
504 < | | > TRAFFIC LIGHT ATTENTION < | | > Undefined < | | > 00
505 < | | > AIR FRAGRANCE < | | > Undefined < | | > 00
506 < | | > ELECTRICAL VENTIL ATION ADJUSTMENT < | | > Undefined < | | > 00
507 < | | > HOOD TYPE < | | > Undefined < | | > 00
508 < | | > REAR LAMP CONTROL MODULE < | | > Undefined < | | > 00
509 < | | > HOME SAFE LIGHT < | | > Undefined < | | > 00
510 < | | > EXTERIOR LIGHT SHOW < | | > Undefined < | | > 00
511 < | | > ADAPTIVE FRONT LIGHT SYSTEM < | | > Undefined < | | > 00
512 < | | > SECOND BATTERY MONITORING SENSOR < | | > Undefined < | | > 00
513 < | | > ENGINE COOLANT PUMP MODULE < | | > Undefined < | | > 00
514 < | | > BATTERY COOLING PUMP FRONT MODULE < | | > Undefined < | | > 00
515 < | | > HVAC BLOWER MODULE FRONT < | | > Undefined < | | > 00
516 < | | > DRIVETRAIN COOLANT PUMP < | | > Undefined < | | > 00
517 < | | > ELECTRIC DRIVETRAIN COOLANT PUMP < | | > Undefined < | | > 00
518 < | | > OCCUPANT DETECTION SWITCHES 3RD ROW < | | > Undefined < | | > 00
520 < | | > 2ND ROW SIDE AIRBAGS < | | > Undefined < | | > 00
521 < | | > SEAT MATERIAL FOR AUDIO TUNING < | | > Undefined < | | > 00
522 < | | > 3RD ROW SEAT MATERIAL FOR AUDIO TUNING < | | > Undefined < | | > 00
523 < | | > DRIVER DOOR SWITCH TYPE < | | > Undefined < | | > 00
524 < | | > TRANSMISSION LOCKING < | | > Undefined < | | > 00
525 < | | > MOOD LIGHT < | | > Undefined < | | > 00
526 < | | > READING LIGHT < | | > Undefined < | | > 00
527 < | | > E-PEDAL FUNCTION < | | > Undefined < | | > 00
528 < | | > FRONT REDUCER GEAR RATIO < | | > Undefined < | | > 00
529 < | | > REAR REDUCER GEAR RATIO < | | > Undefined < | | > 00
530 < | | > TAILGATE/BOOT LID ANTI-PINCH < | | > Undefined < | | > 00
531 < | | > DRIVER DOOR AND LATCH TYPE < | | > Undefined < | | > 00
532 < | | > PASSENGER DOOR AND LATCH TYPE < | | > Undefined < | | > 00
533 < | | > REAR LEFT DOOR AND LATCH TYPE < | | > Undefined < | | > 00
534 < | | > REAR RIGHT DOOR AND LATCH TYPE < | | > Undefined < | | > 00
535 < | | > ELECTRICAL PARKING BRAKE CONTROL < | | > Undefined < | | > 00
536 < | | > AUTOSTART 2ND ROW CLIMATE < | | > Undefined < | | > 00
537 < | | > BRAKE PAD WEAR INDICATION < | | > Undefined < | | > 00
538 < | | > SHOULDER BELT PRETENSIONER FRONT ROW < | | > Undefined < | | > 00
539 < | | > HIGH VOLTAGE DISCONNECTION < | | > Undefined < | | > 00
540 < | | > REAR ACTIVE STEERING < | | > Undefined < | | > 00
541 < | | > STEERING WHEEL TORQUE ADJUSTMENT < | | > Undefined < | | > 00
542 < | | > SECOND ROW CONTROL SCREEN < | | > Undefined < | | > 00
543 < | | > BATTERY BACKED-UP SOUNDER TYPE < | | > Undefined < | | > 00
544 < | | > EXTERIOR REAR VIEW MIRROR DISPLAY < | | > Undefined < | | > 00
545 < | | > BRAKE PEDAL SENSOR/SWITCH < | | > Undefined < | | > 00
546 < | | > ILLUMINATION SWITCH TYPE < | | > Undefined < | | > 00
547 < | | > ACTIVE ROLL BAR < | | > Undefined < | | > 00
548 < | | > INTEGRATED CHASSIS CONTROL < | | > Undefined < | | > 00
549 < | | > WATER COOLED CHARGED AIR COOLER < | | > Undefined < | | > 00
550 < | | > LUMBAR CONTROL < | | > Undefined < | | > 00
551 < | | > SECOND ROW MEMORY SEAT < | | > Undefined < | | > 00
552 < | | > SECOND ROW POWER HEADREST < | | > Undefined < | | > 00
553 < | | > SECOND ROW SHOULDER ADJUSTMENT < | | > Undefined < | | > 00
560 < | | > EGR COOLANT VALVE < | | > Undefined < | | > 00
561 < | | > DOOR WINDOWS TYPE < | | > Undefined < | | > 00
562 < | | > TRANSMISSION OIL COOLER POSITION < | | > Undefined < | | > 00
563 < | | > VEHICLE TO EVERYTHING COMMUNICATION < | | > Undefined < | | > 00
564 < | | > ACTIVE REAR SPOILER < | | > Undefined < | | > 00
565 < | | > REMOTE STRAIGHT PARKING ASSIST < | | > Undefined < | | > 00
566 < | | > HIGH VOLTAGE BATTERY TYPE < | | > Undefined < | | > 00
1000< | | > Active Engine Mounts Module (AEMM) < | | > Not Mounted < | | > 01
1001< | | > Active Grill Shutter Module (AGM) < | | > Mounted < | | > 02
1002< | | > Active Safety Domain Master (ASDM) < | | > Mounted < | | > 02
1003< | | > Active Spoiler Shutter Module (ASSM) < | | > Mounted < | | > 02
1004< | | > Adjustable Steering Wheel Module (ASWM) < | | > Not Mounted < | | > 01
1005< | | > Alternator Control Module (ACM) < | | > Mounted < | | > 02
1006< | | > Battery Energy Control Module (BECM) < | | > Not Mounted < | | > 01
1007< | | > Battery Monitoring Sensor (BMS) < | | > Mounted < | | > 02
1008< | | > Brake Control Module (BCM) < | | > Mounted < | | > 02
1009< | | > Center Console Switch Module (CCSM) < | | > Mounted < | | > 02
1010< | | > Climate Control Module (CCM) < | | > Mounted < | | > 02
1011< | | > Redundant Brake Control Module (RBCM) < | | > Not Mounted < | | > 01
1012< | | > Driver Information Module (DIM) < | | > Mounted < | | > 02
1013< | | > Combustion Preheater Module (CPM) < | | > Not Mounted < | | > 01
1014< | | > Diesel Particulate Sensor Module (DPSM) < | | > Mounted < | | > 02
1015< | | > Differential Electronic Module (DEM) < | | > Mounted < | | > 02
1016< | | > Drive Mode Switch Module (DMSM) < | | > Mounted < | | > 02
1017< | | > Driver Door Module (DDM) < | | > Mounted < | | > 02
1018< | | > Driver Door Switches (DDS) < | | > Mounted < | | > 02
1019< | | > Driver Monitor Camera (DMM) < | | > Not Mounted < | | > 01
1020< | | > Engine Control Module (ECM) < | | > Mounted < | | > 02
1021< | | > Engine Coolant Pump Module (ECPM) < | | > Not Mounted < | | > 01
1022< | | > High Voltage Battery Coolant Pump (HBCP) < | | > Not Mounted < | | > 01
1023< | | > Gear Shift Module (GSM) < | | > Mounted < | | > 02
1024< | | > Glow Plug Control Module (GPCM) < | | > Mounted < | | > 02
1025< | | > Head Up Display (HUD) < | | > Mounted < | | > 02
1026< | | > Headlamp IR Left (HIRL) < | | > Mounted < | | > 02
1027< | | > Headlamp IR Right (HIRR) < | | > Mounted < | | > 02
1028< | | > Electric Drivetrain Coolant Pump (EDCP) < | | > Not Mounted < | | > 01
1029< | | > Electronic Gear Selector Module (EGSM) < | | > Not Mounted < | | > 01
1030< | | > Transmission Actuator Control Module (TACM) < | | > Not Mounted < | | > 01
1031< | | > OBD Firewall Module (OFM) < | | > Mounted < | | > 02
1032< | | > Humidity Sensor (HUS) < | | > Mounted < | | > 02
1033< | | > Infotainment Head Unit (IHU) < | | > Mounted < | | > 02
1034< | | > Interior Movement Sensor (IMS) < | | > Not Mounted < | | > 01
1035< | | > Inverter ERAD Module (IEM) < | | > Not Mounted < | | > 01
1036< | | > Inverter Generator Module (IGM) < | | > Not Mounted < | | > 01
1037< | | > Center Stack Display (CSD) < | | > Mounted < | | > 02
1038< | | > Headlamp Control Module Left (HCML) < | | > Not Mounted < | | > 01
1039< | | > Headlamp Control Module Right (HCMR) < | | > Not Mounted < | | > 01
1040< | | > Occupant Weight Sensor (OWS) < | | > Not Mounted < | | > 01
1041< | | > On Board Charger (OBC) < | | > Not Mounted < | | > 01
1042< | | > Overhead Console (OHC) < | | > Mounted < | | > 02
1043< | | > Overhead Console Rear (OHCR) < | | > Mounted < | | > 02
1044< | | > Passenger Door Module (PDM) < | | > Mounted < | | > 02
1045< | | > Supplementary Restraint System (SRS) < | | > Mounted < | | > 02
1046< | | > Park Assist Module (PAM) < | | > Mounted < | | > 02
1047< | | > Power Operated Tailgate (POT) < | | > Mounted < | | > 02
1048< | | > Power Seat Module Driver (PSMD) < | | > Mounted < | | > 02
1049< | | > Power Seat Module Passenger (PSMP) < | | > Mounted < | | > 02
1050< | | > Power Seat Rear Left (PSRL) < | | > Not Mounted < | | > 01
1051< | | > Power Seat Rear Right (PSRR) < | | > Not Mounted < | | > 01
1052< | | > Power Steering Control Module (PSCM) < | | > Mounted < | | > 02
1053< | | > Power Steering Control Rear (PSCR) < | | > Not Mounted < | | > 01
1054< | | > Airborne Particulate Matter Sensor (APMS) < | | > Not Mounted < | | > 01
1055< | | > Redundant Battery Monitoring Sensor (PBMS) < | | > Not Mounted < | | > 01
1056< | | > Radiator Anti Tampering Device (RATD) < | | > Not Mounted < | | > 01
1057< | | > Rain and Light Sensor Module (RLSM) < | | > Mounted < | | > 02
1058< | | > Rear Console Switch Module (RCCM) < | | > Not Mounted < | | > 01
1059< | | > Rear Driver Door Module (RDDM) < | | > Mounted < | | > 02
1060< | | > Rear Passenger Door Module (RPDM) < | | > Mounted < | | > 02
1061< | | > Rear Seat Entertainment (RSE) < | | > Not Mounted < | | > 01
1062< | | > Safe Stop Module (SSM) < | | > Not Mounted < | | > 01
1063< | | > Restraint Module Left (RML) < | | > Mounted < | | > 02
1064< | | > Restraint Module Right (RMR) < | | > Mounted < | | > 02
1065< | | > Electric Machine Rear Left (EMLR) < | | > Not Mounted < | | > 01
1066< | | > Electric Machine Rear Right (EMRR) < | | > Not Mounted < | | > 01
1067< | | > Integrated Starter Generator Module (IGSM) < | | > Undefined < | | > 00
1068< | | > Seat Fold Module 3:rd row (SFM3) < | | > Not Mounted < | | > 01
1069< | | > Seat Heating Module Left (SHML) < | | > Mounted < | | > 02
1070< | | > Seat Heating Rear Left (SHRL) < | | > Not Mounted < | | > 01
1071< | | > Seat Heating Rear Right (SHRR) < | | > Not Mounted < | | > 01
1072< | | > Seat Heating Module Right (SHMR) < | | > Mounted < | | > 02
1073< | | > Side Obstacle Detection Left (SODL) < | | > Mounted < | | > 02
1074< | | > Side Obstacle Detection Right (SODR) < | | > Mounted < | | > 02
1075< | | > Steering Angle Sensor (SAS) < | | > Mounted < | | > 02
1076< | | > Steering Column Lock (SCL) < | | > Mounted < | | > 02
1077< | | > Steering Wheel Module (SWM) < | | > Mounted < | | > 02
1078< | | > Steering Wheel Switch Module (SWSM) < | | > Mounted < | | > 02
1079< | | > Sun Sensor (SUS) < | | > Mounted < | | > 02
1080< | | > Suspension Module (SUM) < | | > Mounted < | | > 02
1081< | | > Telematics Module (TEM) < | | > Not Mounted < | | > 01
1082< | | > Television Module (TVM) < | | > Not Mounted < | | > 01
1083< | | > Trailer Module (TRM) < | | > Mounted < | | > 02
1084< | | > Transmission Control Module (TCM) < | | > Mounted < | | > 02
1085< | | > Transverse Differential Module Rear (TDMR) < | | > Not Mounted < | | > 01
1086< | | > Vehicle Connectivity Module (VCM) < | | > Mounted < | | > 02
1087< | | > Vehicle Dynamics Domain Master (VDDM) < | | > Mounted < | | > 02
1088< | | > Central Electronic Module (CEM) < | | > Mounted < | | > 02
1089< | | > Wide Angle Vision Module (WAM) < | | > Mounted < | | > 02
1090< | | > Wiper Motor Module (WMM) < | | > Mounted < | | > 02
1091< | | > Air Condition Control Module (ACCM) < | | > Not Mounted < | | > 01
1092< | | > Adaptive Headlamp Module Left (AHML) < | | > Mounted < | | > 02
1093< | | > Adaptive Headlamp Module Right (AHMR) < | | > Mounted < | | > 02
1094< | | > Audio Module (AUD) < | | > Mounted < | | > 02
1095< | | > Auxiliary Water Pump (AWP) < | | > Not Mounted < | | > 01
1096< | | > Battery Backed-up Sounder (BBS) < | | > Not Mounted < | | > 01
1097< | | > Battery Control Switch Module (BCSM) < | | > Mounted < | | > 02
1099< | | > Exterior Sound Module Rear (ESMR) < | | > Not Mounted < | | > 01
1100< | | > Exterior Sound Module (ESM) < | | > Not Mounted < | | > 01
1101< | | > Front Full-LED Module Left (FFML) < | | > Mounted < | | > 02
1102< | | > Front Full-LED Module Right (FFMR) < | | > Mounted < | | > 02
1103< | | > Foot Movement Detection Module (FMDM) < | | > Mounted < | | > 02
1104< | | > HVAC Blower Module Front (HBMF) < | | > Mounted < | | > 02
1105< | | > HVAC Blower Module Rear (HBMR) < | | > Not Mounted < | | > 01
1106< | | > High Voltage Coolant Heater (HVCH) < | | > Not Mounted < | | > 01
1107< | | > Illuminated Decotrim Module Driver Rear (IDDR) < | | > Not Mounted < | | > 01
1108< | | > Illuminated Decotrim Module Driver (IDD) < | | > Not Mounted < | | > 01
1109< | | > Illuminated Decotrim Module Passenger Rear (IDPR) < | | > Not Mounted < | | > 01
1110 < | | > Illuminated Decotrim Module Passenger (IDP) < | | > Not Mounted < | | > 01
1111 < | | > Illuminated Decotrim Module Roof (IDR) < | | > Not Mounted < | | > 01
1112 < | | > Interior Rear view Mirror Module (IRMM) < | | > Mounted < | | > 02
1113 < | | > Multiband Antenna Module (MAM) < | | > Mounted < | | > 02
1114 < | | > Optical Media Drive (OMD) < | | > Not Mounted < | | > 01
1115 < | | > Rear Seat Heat Control (RSHC) < | | > Not Mounted < | | > 01
1116 < | | > RSE Display Module Left (RDML) < | | > Not Mounted < | | > 01
1117 < | | > RSE Display Module Right (RDMR) < | | > Not Mounted < | | > 01
1118 < | | > Seat Comfort Module Left (SCML) < | | > Mounted < | | > 02
1119 < | | > Seat Comfort Module Right (SCMR) < | | > Mounted < | | > 02
1120< | | > PreSideNT_L (PSNTL) < | | > Not Mounted < | | > 01
1121< | | > PreSideNT_R (PSNTR) < | | > Not Mounted < | | > 01
1122< | | > Rear HVAC Electric Heater (RHVAC) < | | > Not Mounted < | | > 01
1123< | | > Overhead Console Rear Left (OHRL) < | | > Not Mounted < | | > 01
1124< | | > Overhead Console Rear Right (OHRR) < | | > Not Mounted < | | > 01
1125< | | > Overhead Console Third Row (OHTR) < | | > Not Mounted < | | > 01
1126< | | > Electrochromatic Roof Module (ERM) < | | > Not Mounted < | | > 01
1127< | | > Sun blind Module Driver side Rear (SMDR) < | | > Not Mounted < | | > 01
1128< | | > Sun blind Module Passenger side Rear (SMPR) < | | > Not Mounted < | | > 01
1129< | | > Rear Passenger Door Switches (RPDS) < | | > Not Mounted < | | > 01
1130< | | > Sun Roof Module (SRM) < | | > Not Mounted < | | > 01
1131< | | > Low Voltage Battery Module (LVBM) < | | > Undefined < | | > 00
1132< | | > Forward Looking Camera (FLC) < | | > Not Mounted < | | > 01
1133< | | > Front Radar Module (FRM) < | | > Not Mounted < | | > 01
1134< | | > Brake Booster Module (BBM) < | | > Not Mounted < | | > 01
1136< | | > Wireless Phone Charge (WPC) < | | > Not Mounted < | | > 01
1137< | | > Parking Assistance Camera (PAC) < | | > Not Mounted < | | > 01
1138< | | > Seat Module Left (SML) < | | > Not Mounted < | | > 01
1139< | | > Seat Module Right (SMR) < | | > Not Mounted < | | > 01
1140< | | > Accessory Gateway Unit (AGU) < | | > Not Mounted < | | > 01
1141< | | > Vehicle Computational Unit 1 (VCU1) < | | > Not Mounted < | | > 01
1142< | | > Brake Control Module 2 (BCM2) < | | > Not Mounted < | | > 01
1143< | | > Forward Looking Camera 2 (FLC2) < | | > Not Mounted < | | > 01
1144< | | > Telematics Connectivity and Antenna Module (TCAM) < | | > Not Mounted < | | > 01
1145< | | > Vehicle Gateway Module (VGM) < | | > Not Mounted < | | > 01
1146< | | > Body Tail Light Left (BTLL) < | | > Not Mounted < | | > 01
1147< | | > Body Tail Light Right (BTLR) < | | > Not Mounted < | | > 01
1148< | | > Trunk Tail Light Left (TTLL) < | | > Not Mounted < | | > 01
1149< | | > Trunk Tail Light Right (TTLR) < | | > Not Mounted < | | > 01
1152< | | > Seat Heating Rear Module (SHRM) < | | > Not Mounted < | | > 01
1153< | | > Autonomous Drive Washer Module (ADWM) < | | > Not Mounted < | | > 01
1154< | | > Active Wing Module (AWM) < | | > Not Mounted < | | > 01
1155< | | > Inverter High Voltage Front Axle (IHFA) < | | > Not Mounted < | | > 01
1156< | | > Mid Voltage Battery Monitor (MVBM) < | | > Not Mounted < | | > 01
1157< | | > Mid Voltage Conversion Module (MVCM) < | | > Not Mounted < | | > 01
1158< | | > Integrated Starter Generator Module (ISGM) < | | > Not Mounted < | | > 01
1159< | | > Outside Heat eXchanger Valve (OHXV) < | | > Not Mounted < | | > 01
1160< | | > Electrical Expansion Valve (EXV) < | | > Not Mounted < | | > 01
1161< | | > Air Condition Compressor Module A (ACCA) < | | > Not Mounted < | | > 01
1162< | | > High Voltage Heater Alfa (HVHA) < | | > Not Mounted < | | > 01
1163< | | > Climate Coolant Valve Module (CCVM) < | | > Not Mounted < | | > 01
1164< | | > Front Side Radar Left (FSRL) < | | > Not Mounted < | | > 01
1165< | | > Front Side Radar Right (FSRR) < | | > Not Mounted < | | > 01
1166< | | > Front Looking Radar (FLR) < | | > Not Mounted < | | > 01
1167< | | > Power Steering Control Module (PSC) < | | > Not Mounted < | | > 01
1168< | | > Compartment Coolant Pump Module (CCPM) < | | > Not Mounted < | | > 01
1169< | | > Coolant Pump for Electric Drive (CPED) < | | > Not Mounted < | | > 01
1170< | | > Battery Coolant Pump Module (BCPM) < | | > Not Mounted < | | > 01
1171< | | > Auxillary Telematic Module (ATM) < | | > Not Mounted < | | > 01
1172< | | > Seat Module Back (SMB) < | | > Not Mounted < | | > 01
1173< | | > Seat Module Driver (SMD) < | | > Not Mounted < | | > 01
1174< | | > Seat Module Passenger (SMP) < | | > Not Mounted < | | > 01
